I have an ***** GTV and the red air bag light has just come on dashborad, think it may have been when passenger seat was pushed back, does anyone know if it is easy to reset and where switch is under seat?
The only way to reset the airbag light is to get you hooked up to a diagnostic machine to clear the error code stored in the airbag ECU. Never adjust the seats with the ignition on, as the seatbelt pretensioner connections under the seat disconnects momentarily when moving the seat and the ECU senses that there is a fault and flashes up the airbag warning light. The airbag system continually monitors for faults when the ignition is on. Any indie garage should be able to do this for about £20.
Unfortunately you need someone with computer, software (i.e. Alfadiag, KWP71Diag, FiatECUScan) and modified KKL cable or just go to service. This is common fault of Gtv.
There is only one solution - remove cable's connector (yellow) which is under seat and solder wires.
