Hi All, just wondered if anyone has any ideas about the main airbag light not coming on at all, the passenger one works Ok
Had the same problem, took out the dials and found a previous orner/ repairer had removed the bulb/ led !!!
Soldered in a replacement and of course the new bulb was on all the time!!!
The problem was that someone had replaced a wheel bearing with the wrong part! Replaced and the light went out.
This was on a 2003 P2 spider
Rich ;)
How do you remove the dash to get to the bulb/LED on the rear and how does a wheel bearing affect the airbag light
Undo the 2 allen key bolts and pull out the whole speedo/ rev counter unit. There are two electrical connections to undo. Remove 6 or so small screws to take the unit apart
Aghhhh maybe mine was the ABS light missing. The fault was solved by replacing wheel bearing with correct sensor!!! LOL
Rich
Is it a MOT failure not having the Airbag light working, thanks for the replies will have a look and let know what the issue is/was.
