1 - 1 of 1 Posts
fellas, my air bag light ( the red one is on )
I checked with my FiatECUscan and had the following error. -
01 - Control Unit Fault
The ECU indicates a defect in the internal components. Verify that the ECU receives interference free power and has a solid ground connection. Clear the code, test drive the vehicle and ensure that the code does not reappear
The reason for this fault is Unknown / Internal error
The current status of the fault is Intermittent / Present
The error counter value is 128
I just dont know where to start!!
the error will not reset on FES and i have tried to disconnect the battery also.
1 - 1 of 1 Posts
