Ok i drove over a curb at 50 kph trying to avoid another driver coming into my lane.:cry:
Apart from minor cosmetic damage i am trying to work out the severity of the mechanical damage.
Bearing housing snapped clean. fixable.
tyre and alloy damaged. fixable.
But there is a clean break in what i am calling an axle mount. it attaches to the back of the block. Is it cast into the block or a separate part that could be replaced?:confused:
http://i227.photobucket.com/albums/dd74/lanipher/20140824_095449.jpg
20140824_095220.jpg Photo by lanipher | Photobucket
Also the gearbox leaked all its oil where the axle enters the gearbox.
20140824_095319.jpg Photo by lanipher | Photobucket
But ti does look like the axle has slipped out about 1cm.
http://i227.photobucket.com/albums/dd74/lanipher/20140824_094521.jpg
'98 GTV V6
Sorry to hear about your misfortune, there are always some [email protected]£!hole on the road. Looks fixable to me. I think that the oil filter mount/axle mount that you refer to just bolts onto the block I'm my opinion. Might be able to source one from a scrap yard.
The shaft exiting the box can move a little bit and the leak may be either due to the seal being damaged or the shaft being damaged but luckily it all seems easily repairable.
Thanks guys. I recon it is easier than i first thought.
The insurance assessor had a look today and has considered it a what we call in au a repairable write off.
So i will be keeping it and fixing it my self.
