1 - 9 of 9 Posts
My radio reception has suddenly deteriorated. As a quick check I pulled out the radio/CD and removed the aerial, stuck in a bit of wire - reception back as it should be. I have removed the rear interior light to see if there was a bad connection - but that seems fine.
It there an amplifier in the aerial circuit and if so, where are the connections? Is there likely to be a fuse?
Discussion Starter #2
anyone have any ideas?
Intrested also since mine went a few months ago, the reception now is lousy, is there a amp for the antena? oh! btw how do you take the head unit out, i've a connectnav
Yes there is a signal amplifier at the back of the car near the antena, but not sure about the exact location, is powerd by a wire from the radio
Alfa romeo gt we
My reception is rubbish , has anyone replaced ariel mount on gt , i cant seperate the single ariel wire from base to main ariel wire under headlining ?? Tried pulling it apart but wont seperate ....
Amplifier is in base of aerial powered by feed through aerial coax, called Phantom I think. To seperate above connector (Raku1) slide back the black collar with slots in.
1 - 9 of 9 Posts
