I'm looking to replace the wheels on my ph2 gtv v6. I've upgraded the suspension to the Koni Sport shocks with Eibach springs so it does ride a bit lower than stock. Does anyone run a similar setup on 18x8J rims and if so, what would be the best offset to ensure I don't start rubbing body work (current offset is 30.5mm); should I reduce the offset by 6mm to keep the inner rim position in the same place, (outer rim moves outboard by 12mm), keep the same offset (both rims move 6mm) or increase the offset by 6mm to keep the outer rim in the same place (inner rim moves inboard by 12mm).
Ordinarily I would have kept the inner rim in the same place to ensure no clearance issues with suspension components etc, however moving the outer rim outboard seems to be a problem on the rear as a straightedge across the tyre currently just touches the inside of the return lip on the bodywork, so any outboard movement is likely to rub if the suspension compresses by more than 30mm. Would moving the inner rim inboard 12mm create any clearance issues?
Any advice is greatfully received, many thanks,
Gareth.
Gareth.
