hi all. new alfa owner 156 broken passenger window switch. the switch on the drivers door panel ( for said window) sometimes works the window ..... and sometimes won't. when it won't work there is a clicking from behind the glove box, prob a relay switch?? any ideas and a possible costing ?? thanks
I had this on my old 156... if you open the glove box there should be a small hatch in the roof/top of the glovebox... open it and have a feel... i found the relay that 'clicks' hanging out and needed pushing back in slightly... to what i dont know as you cant see in there... but it seemed to work...
But the clicking sound is good and means the relay is working... mine would stop clicking when the window stopped working, and only click when it worked so i guess your relay is ok and the problem is further down the line... either the window switch itself or maybe window motor or regulator....
