Just after some advice post thermostat replacement.
I put it all back together and filled up the coolant to just beyond max expecting the system to suck some fluid instantly when I pumped the hoses by hand...nothing happened coolant level stayed the same.
I then fired up the engine and let it idle and coolant was dropping from the small pipe into the coolant res, it seemed to heat up ok and the thermostat kicked in and started sending hot fluid through the big pipe which was nice. However even after all this the coolant level didn't drop much at all.
Is this normal? It is still sitting above max as we speak.
Its a 156 2.0 by the by.
