Alfa Romeo 159 2.2 JTS 185hp
Hi! Does somebody know how to adjust the hights of the low beam on a 159? The right side points way too low and the left side is normal. Haven't realized it until I changed the low beams to h7 xenon. I have checked that the bulb is firmly in place. I tried to turn the long bolt coming from the backside of the headlight, but it seemed to do nothing. If you know what I'm doing wrong, please help! This is a picture I found on google, but the circled bolt is the one I tried to turn.
When you changed the bulb it’s possible you popped the reflector off the ball on adjuster. Take bulb cover off and see if the reflector moves around
The two bolts have different functions -the one bolt in the middle adjusts side to side-(I think that’s the one you’ve been adjusting and probably harder to see any movement)and the one nearest the wing is vertical adjustment.
