I'm wanting to add 3.5mm connectivity to the standard Blaupunkt CD head unit in my 2005 Alfa 156SW.
Having read THIS thread I ordered one of THESE.
Having read the previous thread it appears that the lead will disable the CD player, but that this can be worked around using THESE instructions.
I have a few questions about what I need to do (my lead won't be here for a week or 2 so I've plenty of time to sort it all out).
Cheers,
Ecnarfi
- My car doesn't have a CD Changer and cycling through the head unit's menu options doesn't show a CD-Changer or an AUX option. Is this option likely to appear when the lead is connected or will I have to jumper the data connections and add a switch to let me choose between the CD and the 3.5mm line-in?
- Assuming I need to do it, how do I connect the jumper wires for the data connection in the back of the blue connector? Are there specific connector spades I can buy or is it a matter of a steady hand with a soldering iron?
- Assuming I need one, are there any suggestions for neatly/discretely adding the switch into the cabin. I'm thinking of removing the spring from the lid of the ashtray so that it sits permanently closed and fitting it to that.
- I've been considering a switch like THIS or THIS. Those switches have 3 connections (Power, Acc & Ground) which ones will the data connectors go to? I suspect Acc and Ground, does this mean the LED won't light (if so I'll just get one without an LED eg THIS)?
Cheers,
Ecnarfi
