Does anyone know the cure for a sticking accelerator pedal?
Mine is particularly bad at low speeds around town - causing the car to jolt.
Is it likely to be a problem inside the car with the pedal or under the bonnet?
Any help would be appreciated.
Regards
Paul
(95 2.0 TS 16V)
J
make sure that no carpet or sound profing is in the way if needed cut it away..if that doesnt work try a new cable.
frayed cable. Had this when I bought my first Alfa - 164 TS.
St Leonard's Motors (a main dealer) told me the jerkiness was normal & probably because the car hadn't been used much & needed lubing.
Thanks for the advice. I'll try and have a look at it at the weekend.
I've also not yet managed to find a main dealer in the south east thats worthy of a recommendation!
Regards
Paul
(p.s. does anyone know how much a thottle cable is and how easy it is to fit - is it something best left to a garage?)
F
Hi paul,if you look at the cable at the throttle body end where the cable is bare, u should see a thin white plastic sleeve inside the black sleeve,this came out all the way on me on a 93 155 and caused my cable to stick.I cut it off and it cured the problem.Good luck
Alan
Keep her clean
I also had a sticky pedal with my 2.0 16v 38k miles. All that was needed was to grease the pedal arm throu the two plastic support/guides up in the footwell.
