trying to track down any store that sells just the pulley and bearing. Any help appreciated
You won t find any
The air con compressor on the 2.4 has two pulley. The outer one runs the air con.
I had to change my compressor a while back because the pulley failed.
It is the rubber that fails on it.
I spoke to the manufacturer directly back than in Poland and Check Rep (I called the factories) and there is no pulley sold as a stand alone replacement being sold
You have to buy a new compressor or use a second hand one
A new air con compressor from Alfa or Specialist will cost you about 拢800
A rip off
Not sure where you are based but I ordered mine from here http://www.lmsspares.co.uk
Paid less than 拢300 for same manufacturer as original part
Thx for the reply, strange that is not possible to find. I know some BMW 7 series that are using the same unit. Im just going to change the bearing and hope for the best馃槀
