My 916 Spider just failed its MOT, The ABS light will not come on. The garage told me to try changing the bulb. How do I change the bulb. I have taken the instrument panel out.
Thank you for you input Stixy.It's not a bulb, it's a LED, so I very much doubt that this is you problem. How handy are you with a multimeter, you could see if power is supplied to the pin in the instrument plug for the ABS. More likely a fuse to the ABS system as blown or worse. What year is your car? As there are differences with the ABS over the years & I upload a wiring diagram for ya..
