Hi, I have read all the previous information and just before I start replacing parts I would like an opinion or to. I have the ABS/ Handbrake light/ Speedo not working combination. But sometimes I turn the engine on and all is fine then it will go back to not working and the ABS light will flicker when I use the brake. I also have a invoice in the history for the ABS unit to have been replaced with a recon part in may 2012. Any ides I could try would be welcome. Its a 2.0 T.S Spider year 2000.
Thanks Mike
Hi mate i had the exact same problem and the info kept leading me in different locations
so i took the plunge and bought a ABS pump/ecu and it cured the problem straight away
Shame the other one on yours only lasted since 2012 must just be bad luck
hope this helps i spent months trying to find the problem
Got it from steve clark alfa breakers in birmingham for £55
Thanks for the advice and replies, Looks like I will have to get a recon unit.
I will get all the lights out on the dash.
On my TS the ABS light would flicker on and off. There was something you could do to get it to come on but I cant remember, it was a while ago.
I took it to a gravel car park to test it out, when the light was off it would work and low and behold, when the light was on it would skid to a stop.
I can't remember why (maybe budget) but knowing the discs and pads were shot I left it in to my mechanic to replace them and the brake fluid but I didn't change anything to do with the ABS or anything else.
When I got the car back the ABS problem had gone completely and never came back in the couple of years I kept it for.
So, to cut a long story short, it might be worth checking out the condition of the rest of your braking system first. I suspect it was dirt in the fluid causing a blockage but who knows.
Thanks Jon, I tried some very heavy braking when the lights were out and the speedo was working. im sure I got the abs activated but the lights came back on. I will try giving all the brakes a clean out with compressed air.
I have found a company www.autotekelectronics.com who say they can repair the control module if I send them that, with no need to interfere with the ABS pump. Sounds like the way to go.
So I sent the ABS unit to them got it back fitted it and speedo works,abs/handbrake light out. So happy with the fix. Thanks
