About 2 months ago I has the ABS/ESR fault happening every time I got in the car this would normally come on within the first 10 minutes of driving. That lasted for about 5 or 6 weeks, then everything seemed fine and no fault came up for about two weeks until 3 days ago where it comes on straight away every time I start the engine.
Driving back from work the other day my mum just happened to be behind me and noticed a cable dangling down underneath the car, on closer inspection it seems to run straight through centre, from front left to back right and there is a designed recess for the wire to follow but a bracket appears to have been damaged which is why it's now hanging.
My work is up a cobbled road with killer speed bumps so could the cause be a loose fuse which has been "shoogled" out of place by driving along cobbles everyday, twice a day or is this cable something to do with the ABS system and more likely to be the cause? Any opinions would be greatly appreciated.
