Hello everyone. This week I had a problem with my 147 16v jtdm. I had to change a complete transmission, left side. I used one of a GT with same engine. After installing I got the error of the abs vdc and esp. I looked at it and noticed that the sensor of abs was broken, replaced it and problem was apparently solved and the error dissapeared, but after driving 50 meters error appeared again, already checked the sensor but seems okay. What can it be?
You need to plug MES in see what faults logged or you are just guessing at cause,sounds like a wheel speed fault but MES will pinpoint which one to focus attention on
I already did it before changing to new sensor and error was signal in fault in FL wheel. When changed to new one error dissapeared, after 50 meters got it again
Bit of a guess but have you tried looking at the fuses? On the 156 there is a 60A fuse on the battery that powers the ABS, taking it out gives ABS, VDC and EBD fault.
