Hello all, seems my abs ecu has failed on my 156.....
speedo not workin and handbrake and abs lights on.
my car is a 2.5v6, can anyone please tell me if the abs pump is the same as twinspark models so i can source a second hand unit.
thanks
0
Is V rare for a ECU to pack up IMHO - mebbe take yer car to a 'good' indy :)
M
Check the large bolted in fuses on the positive terminal as they are the main feed for the ecu..
This fault was intermittent at first then speedo completely failed....
have had no speedo for couple of months now :rolleyes: need to sort it before i get done fo speeding :D checked all fuses and connections with no luck, battery is new and charging ok. driving me mental now!!!!! if its not abs ecu...what else can it be?
:confused: :)
Where do i start??? bloody wiring loom!! sounds like a headache.
Will see what i can do :(
alfa ownership been great till now.......
cant complain...1st real fault:)
the abs system has TWO fuses.
depedning on the age the MAIN fuse is around the battery, either 50amp 'bolt' on type as redx described OR if older < 2000 then its a YELLOW 60 amp inside a fuse holder between battery & bulkhead
then INSIDE at the driver knee is another 5 or 10amp.
rem there are TWO fuse boxes at driver knee, the main one has 20 or so fuse, easily accessible + another 12 or so ABOVE that fuse box, PITA to get at.
Hi, on a similar note my 156 jtd has started giving an abs/vdc and occaisionally ebc fault. It comes on during start check but can then dissappear for several miles before reappearing. I have used Unidiag but no braking system fault codes were detected. Slight continuos squealing from rear left break but pads look reasonbly ok. Any ideas?
