I have received all the parts to do my first timing belt change. Any advice about things I might come across?
The waterpump came with a paper gasket?? it kind seems wrong using paper as a seal for water. Does it need gasket cement? Also the new tensioners have no springs. Do I use the original springs?
This is what I got from reading the haynes manual.
Remove fan from radiator
remove radiator
take pully covers off
align mark on flywheel to timing mark by pushing car in 5th gear
remove cam covers
loosen tensioners off and take belts off
take waterpump pully off
remove water pump
install new waterpump
align cam timing marks to marks on cam housing
slip belts on making sure marks stay lined up
put on new tensioner and tighten up
waterpump pully back on
all input much appreciated.
remove radiator
remove cam covers
remove water pump
