So I fitted the simulator/cheater today. I will post those results next week.
The results of the blanking plate with a check engine light:
The fuel econemy is back to old values: 15.41 km/l || 36.25MPG However this was incl 3 regenerations, so i'm certain it improved a little bit more than normal.
The strang thing though that was that it looked like my car switched between maps (if that is even possible). Perhaps because it doens't really know which sensor to trust, depending on the reading it switches map? I drive the same 200km highway everyday, since I live in the very flat netherlands I know this road very well. On specific points on the road it could do 14.5km/l || 34.11MPG while driving 120km/h 75Mph the next day, on the same part of the road with the same outside conditions (wind speed/wind direction) while driving the same speed, it could do 17.5km/l || 41.16mpg. Encouter this phenomena multiple times. Could be just an coincidence.
Anyway I fitted the simulator and did some ECU readings to see if it makes any affect on any of the sensor readings. Attached you will find 4 files (csv extension) This you can open with multiecuscan and check or uncheck some of the parameters to get a better view.
2 of the files are before I fitted the simulator/cheater. 1, in neutral gear with some various engine speeds. The other one is a short ride around the block. Same goes for the 2 files with the EGR simulater/cheater in place.
It seems that my turbo overboosts, do not really know if that's because of the EGR blanking plate, haven't noticed this overboost before.
Anyway, enough talk time for some attachments.
EGR simulator/cheater FiatMultiEcoScan graphs
Might be worth your while putting some fuel readings onto a graph, your air figures seem to be all over the place. How is it driving in general now, with blanking, and then with simulator ?
