Hi Chip
I see Brenton has responded to your queries and I agree with what he's said so nothing much to add. So, I'll just clarify the state of my 159 JTD before fitting the gadget and what work I did when fitting:
Before:
No modifications to the car at all that are relevant to this modification. The car stuttered around 1500-2000 RPM when applying light throttle. Typical scenario would be cruising along in a 60kmh zone and it jack-rabbiting down the road, even on cruise control.
Modification:
Pre-fitted the electronic simulator and checked pin voltage as per instructions. Everything checked out so I proceeded with the mechanical items. I fitted the 2 gaskets and metal blanking plate to the underside of the EGR housing. These were part of the simulator kit. I then fitted the electronic simulator as per the instructions and tested again, all clear.
I took it for a quick drive immediately and a longer drive the following morning. I have since been out again and on all 3 occasions the car runs as if it were new. To me, after driving it with this cough, driving it like it was new is a HUGE improvement. This is what I mean by it feeling like a new car. Everything is more smooth, the gear changes are smoother, the engine is slightly quieter, cold starts are much improved and cold idling is constant and smooth with no misfires or coughs. I used to get blue smoke on start up and now there is none. The heavy smell of unburnt diesel is also now gone.
I can't explain all of the changes Chip. I can only describe the improvements. However, with 100% certainty, this has fixed the problem.
I hope this helps clarify what I did to cure this particular problem
