A little cough...
9311 Views 87 Replies 18 Participants Last post by  smhaze
Dear all,
Not a huge problem this, it certainly doesn't happen all the time, and it's mostly out of curiosity that I'm enquiring.
I find, occasionally, in 2nd and 3rd gears when accelerating slowly (such as when coming off a roundabout and getting back up to speed), that the 159 gives a little cough. It tends to happen at just over 2000 rpm. It's almost as if briefly the engine loses fuel or air supply.
It's a diesel, a 1.9 JTDm.
The EGR and throttle body have recently been removed and cleaned, as I thought this could have caused some of it. I have not had the EGR blanking plate / remap done.
Another thing that may valuable to know is that the acceleration profile in first gear (only) is not smooth. Up to around 3000rpm it is as smooth, but after this there is a giant kick up to 4000. I was thinking that perhaps the lumpy acceleration profile and the cough are related.
Has anyone else experienced anything similar, or have any ideas about what may be causing this?
All the best,
Andy
(Apart from this a very happy 159 owner)
1 - 20 of 88 Posts
It is still highly likely the EGR has something to do with this, it may be sticking open a little too long. Try restricting/ blanking, and seeing if this makes a difference, a plate is less than £4, so a cheap check, and worth keeping long term.
Also possible that the MAF needs a check
It sounds like something to do with turbo control. Either the VGT vane actuator and mechanism are stiff/loose or worn. Or the Boost control solenoid might be dirty or faulty
Here's the boost control solenoid and the sponge filter inside which can become blocked BCVS | Flickr - Photo Sharing!
Mine has actually failed completely, but the car still runs well with the turbo valve wide open all the time ;) !
The VGT vane is located under the inlet housing of the turbo - stood in front of the bumper looking at the front of the engine it is in front of your left knee mounted close to the engine block. Yoiu can see it when yoiu look up from underneath with the undertray off. I gave mine a good spray with a spray lube. I pulled off the vacuum pipe for the actuator and blew/suck to make sure everything was free and then checked the vacuum pipes fo leaks/splits
I also have this problem Andy,I thought it maybe dirt in one of the injectors but im still non the wiser.
I forgot to mention it's also worth cleaning the injector electrical plugs.
When this engine is used in Vectras with an identical harness there seems to be a problem, particularly with injector 3 plug become slightly corroded. Just reseating the plugs might help, but regardless of how clean they look a spray with a good quality contact cleaner (not wd40 !) might help. It did in my case.
(The problme is so bad on Vauxhalls that they have issued an injector 3 electrical plug replacement mod kit !)
  • Like
Reactions: 2
Thanks all for your replies so far!
I hadn't even considered it could be turbo related. While out for a drive today, I did observe that when the cough occurs, there is a drop in turbo pressure - not a great deal, up to about one notch on the gauge.
Also during the jump in acceleration in first gear, there is an even bigger drop in turbo pressure when this occurs.
I'll try the cheapy things first - checking the sponge is clean, cleaning injector electrical plugs, perhaps the EGR blanking plate. Here's hoping that we won't have to get involved with MAFs and turbos too much...!
  • Like
Reactions: 1
Alfa Diesel 'cough'
Hi all
I've been reading through various threads over the last 2 to 3 years on the topic of Alfa Diesel 'coughs'. I have a 2009 159 JTD Ti 2.4 wagon/estate and it's hands down drop dead gorgeous. It has about 63k km's on it now and for the last 15k-20k it has sadly developed this annoying cough. I've read some of the comments and I would like to detail what I have done in order to try and fix it (which to date I have not):
1 - Injector cleaning - all 5 injectors were taken out and professionally cleaned by a mobile Bosche mechanic. This did nothing although probably extended the life span of them so I wasn't too unhappy.
2 - MAF sensor replaced - This did actually cure the problem however withing 3 weeks it was back. I don't believe it was realted.
3 - EGR - Cleaned, checked, tested by same Bosche mobile mechanic. No dice, no change whatsoever.
4 - DPF - This has had more Wynn's DPF cleaner in it than I care to remember. Although it seemed to have an effect, it wasn't consistent and the percentage blocked readings always ended up at the same % (I have all the software and connection leads to activate a DPF regen)
5 - Running on higher RPM to engage regen - for some time, I traveled to work (40 minute trip of which 20 mins is at around 100km/h in manual mode and keeping the revs above 3000 rpm. Sometimes when I got to work and cruised into the carpark, the engine/exhaust has a deep rumble to it which gave me cause to think I had initiated a DPF regen. However, this did nothing to the coughing situation.
6 - Back drilling the DPF - I got so fed up with the DPF cleaner that I back drilled the DPF after cleaning it out with an industrial pressure washer. This was the several holes version that go through 2/3rds of the DPF, leaving the forward 1/3rd intact. Noticeable increase in performance and response but coughing continues.
7 - Full fuel tank - Thought this had an influence, the fuller it was the less coughing but I'm not convinced now.
8 - New fuel filter - Alfa laughed at me for that one. I've kept the perfectly ok one I replaced in case I need a spare as there was nothing wrong with it.
9 - Now this is weird but I genuinely think it is relevant. Travelling around corners makes it cough violently. There is gentle-is left hander in a 60km/h zone as I leave work and it is guaranteed to cough. Sometimes it is really quite harsh, more harsh than any straight line occurrences. In a similar way, it coughs when I go through a small chicane on the way to work and the left hander after it.
10 - It happens at around 2000 RPM under light acceleration. I've even managed to make it cough on cruise control by setting the speed and using it to increase the speed when on a shallow incline at around the RPM range.
I have spent roughly $3000-$4000 trying all the suggestions on the forums and advice by diesel mechanics. I've posted my findings here so that you can at least ignore the points I'm convinced had no effect.
My latest hypothesis is that it is wiring related and a suggestion in this forum mentioned it could be the injector leads. It's possible that lateral 'g' forces disturb a fault in the leads and that's why it happens more on corners (I know I'm reaching a bit here but I'm running out of reasons).
Alfa would love to have it in but a) it's way out of warranty and b) the chief mechanic has suggested it may be cracked inlet manifold, head issues or worse and given that all the suggestions so far that mechanics were convinced would fix it havent, it's a last resort. the garage bill for that would be probably 2/3rds of the car value.
Anyway, I'll keep an eye on this thread and see if anyone updates it. If I have any breakthroughs I'll post it here. I have some contact cleaner which I will try tonight. When the diesel mechanic replaced the MAF sensor it was faultless for a few weeks and I wonder if some of the wiring was disturbed in that process which cured it for a short time.
I still love it though and I'm not giving up. There is a problem in there and I will hunt it down :)
Happy motoring
See less See more
Just to add that ours has the same thing.
I found that adding 2 stroke oil to the diesel (around 150-200 ml to a full tank) helped for a while, but now it's back to its old tricks. Only difference is that whereas it used to splutter at about 1800rpm, now it does it around 2200rpm
New timing belt, water pump, EGR, thermostat, coolant, oil and fuel filter in the last couple of weeks. And a thorough disconnect of every connector I could find under the bonnet and spray with contact cleaner.
Still does it. :)
  • Like
Reactions: 1
Update on cough
Seems to be a global issue HengistPod and yet Alfa service agents (at least in Australia) seem to know nothing of it. I can only assume admitting it's existence would open a tidal wave of warranty issues or worse. However, as I don't want to wake up next to a horses head, I'm not laboring that point.
If I knew for certain that blanking the EGR, deleting the related ECU map along with the DPF delete for good measure would fix it, I would have it done. I've been quoted around $1200 to have the work locally but as the DPF isn't giving me issues (I can regen it and clean it with the Wurth DPF cleaner if it does block up) I wonder it it makes sense just to have the EGR delete done. Would any of you more knowledgeable members care to comment on this? I know it's been done to death but some of the posts related to this topic are getting on a bit so a refresh would be appreciated. I'm ignoring the legality issues for the moment, even with this the mod, the 159 JTD would pass emissions tests in the UK so I'm certain my carbon footprint would remain considerably less than the multitude of diesel utes that haven't seen a tune up in decades I see on the roads (no such thing as an MOT in Aus, only when you sell it).
It's not the only problem I have with it but the rest of them are minor in comparison. If I could sort this one issue out though.....
See less See more
My 2011 2.0 SportWagon does this as well!
Not all the time admittedly - sometimes it can go weeks between episodes - but when it does happen, it almost always happens in second gear under light-to-medium acceleration as the engine passes through the 2000 rpm mark. The engine isn't quite warmed up when it happens, and it only ever seems to do it once per journey.
It never coughs as such, a hiccup would be closer to it, just a split-second hesitation. The best way I can describe it is as if a misfire occurred.
It's very... um... characterful. I haven't bothered getting it looked into yet because, having come from driving a 1990 Ford Sierra that burped and farted with almost clockwork regularity, it's quite a smooth runner in comparison! :)
  • Like
Reactions: 2
Yep, same here.
Hello to all.
Yes same here. I have a 2008 JTDM 1.9 manual and have the same annoying stutter (and accompanying raa, raa sound) around 2,000 revs.
I have spent many hours trawling through this and various Fiat problems but cannot find a single fix.
I have put in an EGR restrictor plate (Diam shaped plate with the 9mm hole) and that has helped, but it is still there. I know the EGR is working fine as that was recently replaced.
I keep thinking that it maybe a vacuum leak somewhere but have just about eliminated that concern by carefully checking every hose. No leaks.
My current thoughts are:
1) Turbo VGT mechanism that is sticky.
2) The vacuum hose that feeds the VGT solenoid plugs into what I think is the engine variable valve timing mechanism. Why, I do not know and don't yet understand how they interface, but maybe there is an issue with that.
3) Fuel mapping / Software. Maybe as the various engine components and sensors age a bit, the fuel mapping cannot accommodate the combined shift in variables. Guessing here as I do not know.
Like others, if you push the car a little harder through the gears, there is no issue. I also think that it is worse if putting around in traffic for a while as opposed to giving it a few revs down the freeway, then back into low speed. Maybe the extra revs gives it bit of clean out. (I have read that is called an "Italian Tuneup").
I did see a post on this forum somewhere where a guy had made up an interface (Cables and chip) that went between the MAF sensor, MAP sensor and possibly the EGR that I think may have cured the problem, but I can't find that post.:irked:
I keep looking for that magic cure, i.e, finding a post that says "Do this and the stutter goes, works every-time", but unfortunately not.
Looking forward to following this thread.
See less See more
  • Like
Reactions: 1
Found it.
Found the system for EGR delete without remap.
http://www.ebay.com.au/itm/06-EGR-c...946907?hash=item2a4a3a151b:g:iPEAAOSwg3FUrEMb
Anyone here tried it?
  • Like
Reactions: 1
Update on cough Mk2
Hey Brenton - I've not seen that before, I wonder if anyone has had any success with that?
A small update for everyone who is interested. The weekend before last, I disconnected the injectors and cleaned them with CRC CO contact cleaner. I also removed the MAF sensor and cleaned out all the oily deposits on the sensor. Now, I say MAF however it may also be referred to as the MAP. To be clear, it is the sensor that is located in the inlet manifold near the fuel filter. It is removed with a single T20 torx cap head screw. Also, due to poor planning on my part, I filled up with local cheapy diesel as opposed to the religious use of BP Ultimate.
The net result of these 3 actions, and I have no idea if it was a result of one or all all none of them but the car hasn't run this well since it was supposedly fixed at a diesel mechanic about 6 months ago. It ran well for a few weeks then reverted to normal cough mode. I've cleaned this sensor before but it seemed to not make a difference. I just want to say that when it runs like this, I wouldn't part with it for anything, it's transformed.
I know this isn't that helpful as there isn't anything conclusive. You can probably rule out the fuel but I've noticed it runs better on a full tank. Anyway, as this is literally a ten minute job for both the sensor and the connectors, I would say it's worth a shot. It took a day to settle down, I guess you could reset all learnt parameters if you have the software/leads so it started from scratch however a day later, it's running really well. I hasten to add that it isn't cured, it's still there but the frequency and magnitude is vastly decreased.
I am planning to repeat the maintenance of the sensor this weekend. If it comes back, I'll clean the injector connectors. If I have anything conclusive, i'll let you know. :byebye:
See less See more
Hi Britswiss
Yes, it was definitely the MAP sensor that you cleaned as the MAF is located front right corner of the car on the pipe from the air box (located near the front right wheel) and the pipe that goes to the turbo. I had actually replaced the MAP sensor on my car because it broke when I took it out to clean. When I did get it out it was fully caked up, even the little cage supporting the sensor was full up with soot. However, it did not seem to make much difference to the stutter.
I did fit a partial blanking plate, the diamond one with a 9mm hole and that did reduce the stutter greatly, however it is still there, although as you get use to it, I can drive "around" it, so to speak. Still, that's not good enough as I want to eliminate the stutter altogether.
I have ordered one of the EGR simulator kits and another full stainless steel blanking plate and will give that a try. I don't mind spending a little money trying these things because based on other threads on this forum, the cure can be quite hit and miss and many garages simply don't know. Not to mention that every trip to a garage is going to cost about $500.
I did get a quote for a remap and delete the EGR, but keep the DPF (the car just had a new DPF and EGR fitted just before I bought it, probably in an attempt to fix the stutter) and in Perth they wanted AU$950. Gotta be kidding me. So fingers crossed on the EGR simulator.
See less See more
  • Like
Reactions: 1
Continuing...
Hi Brenton
Yes, that sensor was utterly caked with black soot/gunk. I wonder what the inside of the inlet manifold looks like....*shudder*
I'd be very interested in your feedback from fitting the EGR by-pass kit (for want of a better term). I saw it on EBay and I'd certainly give that a go.
As an update, the cough is starting to creep back in again and I have to admit, I'm not convinced anything I have done will work long term. By not allowing the EGR to let the engine breath it's own farts, I think that will help tremendously. Experience dictates I keep my expectations low but I wish you success with the EGR by-pass.
Fingers crossed!
Reading this thread with interest. What is the turbo boost gauge doing when the cough happens? I have a 2.0 jtdm and believe the vnt on mine is sticking so the car tries to overboost and causes a hiccup before returning to normal.
The Pasty.... I like that name. My Wife is originally from Cornwall, so Cornish pasties from time to time, one of my favourites.
The Turbo boost gauge on mine does flutter down with the stutter, but I'm not sure if that is more a symptom rather than related directly to the cause.
When my car stutters, I here a raa, raa noise that is in time with the stutter, which I thought might have been the Turbo VNT system, but lately I am more convinced that it is the swirl vanes actuator that I can here turning off and on, as if it is confused. IE, the ECU parameters that control the Swirl vanes are set too tight, so if a couple of other input parameters are fluctuating, it's causing the swirl vanes to over correct one way, then back the other while on light throttle, accelerating.
However I am guessing as I don't really know, but my "Google Research" on the same did lead me to read about some guy, I think on the Vectra forums, that did widen the swirl vane parameters that cured his stutter. Evidently he had a 2007 Vectra (or similar with a stutter) and a 2011 Vectra (or similar without a stutter) and using software, he compared the swirl vane parameters for both vehicles. What he found was that the 2007 engine had parameters +/- 50 while the 2011 had something like +/- 300 (Can't remember the exact numbers here or vehicle build dates as I linked it on my computer at work, but I think you see the point I am trying to make). So what he did was change the swirl vane control parameters on the 2007 vehicle to match the 2011 vehicle, then the stutter disappeared.
If the EGR simulator doesn't fix the issue, then I think I am going to head down the path of studying the Swirl Vane control parameters and software required to make the change, or find someone who can do it for me for a reasonable cost. I'd like to work out how to do it myself as I like to teach myself and learn how to do stuff. However, if the EGR simulator fixes the stutter, then the issue becomes redundant anyway.
Fingers Crossed. Hopefully the EGR simulator and full blanking plate turns up next week so I can play next weekend.
See less See more
You guys should probably read this Autolusso - Swirl Flap Delete
A worthwhile read, thankyou. Definitely something worth considering. Does the swirl flap delete with the EGR delete cure the dreaded stutter?
Hey Brenton68,
I'm in Perth too, with the same issue on my '09 2.4 Ti. I'm keen to see how this all goes. I've cleaned the egr and Throttle body within an inch of its life and cleaned all the connections too. I recon ,like you, I'm going to get the software etc. and explore the settings...of everything. This stutter is v frustrating.:furious:
1 - 20 of 88 Posts
