21 - 31 of 31 Posts
Hi all, I believe I have this issue. If I remove the sensor and hold it between my fingers to warm it up the compressor kicks in. I've sprayed it with contact cleaner but hasn't made any difference.
Does anyone know where I can see the sensor readings in MES? I think it must be reading much lower than it should and the car thinks it is below zero, but can't find a sensor that looks 'out'?
Has anyone managed to work out if this easy is replaced without a whole loom?
Many thanks, all 👍
On climate control live data I think the temp sensor is referred to as evaporator temperature
Thanks. I looked again earlier and can't find that sensor or any others that change when I hold the sensor in my fingers to warm it up.
As a test I have now clipped the sensor out of the way outside of its housing, as whilst on the drive this seemed to make the compressor kick in as it should. As soon as I put it back in its place it seemingly got cold and the compressor cut out 🤷‍♂️
Like I said, measure across the terminals of the bit you've now cut off and you should be able to easily replace it. If it's working without it in situ then it's more likely a NTC than not :)
have you had pollen filter out and checked it’s not blocked? The temp sensor could be doing what it’s supposed to?
Thanks for your tips, I will need to get hold of a multimeter. I've not cut anything (yet), just unclipped the sensor from its housing and tucked it out the way outside the housing
Yes, new filter was the first thing I did when the a/c started playing up. No change and then went for a regas, which also didn't make any improvements
Mine was just diagnosed as a bad frost sensor. It was fine and i had cold air when i brought it in, but luckily it wasn't working today when I went to get the car, so the fault could be pinpointed. I got a pretty reasonable estimate but the Olympics are delaying all parts deliveries. I love the shop and am thinking of taking out a life insurance policy on the Alfa specialist. Note on Frost sensors: the temperature rarely goes lower than 10C here!
Hello Team!
Another tale of woe with the A/C in a G! Funny how many problems crop up only when the temperature starts to rise in the UK! 😂
Blowers only blowing warmish air, no matter what settings I use on the HVAC controls. I have just had it re-gassed (470g) as it was completely empty (0g), which leads me to think someone's already had it opened up for problem 🤔
So, compressor is working and it's just had full re-gas. Scanned it, with no faults found. The cooling fan doesn't kick in with the A/C, but does to cool the engine.
Any ideas gents?!
The compressor is definitely working? Fan should come on and off depending on the pressure in system. As it works harder the return is hotter which increases pressure and calls for the fan to cool condenser.
When it was gassed did they test the pressures?
Yes, working 100%. Unplugged the pressure sensor to test it, and the compressor cut off. The AC pipes don't cool down either, so the gas isn't being circulated.
I will have the check the pressures question!
Thank you
I would say either compressor is U/S or the signal to it isn’t working properly. The compressor is a variable displacement type so it can run at different power,it’s not just a straight 12v power supply like older type compressors.
have you got MES to check live data to see what is being demanded?
just realised my wording is probably misleading clutch is energised with 12v but that doesn’t just run compressor like older style. The internals control the variable displacement,no idea how though
21 - 31 of 31 Posts
