Hi Alfistis,
Unpleasantness this morning as the engine stalled while in a queue with a quick flash of "low oil pressure warning". Was able to restart without issue but then saw that the temp was rising, running unevenly and eventually smoke developed. Was able to pull over and thought I was low on oil - and also the coolant was running a bit low. Walked to a gas station, topped up oil + coolant (before checking if oil level was OK after resting - my mistake), but realized it wasn't needed and the issue remained. Got a car mechanic over who looked at it for 2mins, then switched off the AC and the issue was fixed... guess I should have thought of that.
Net: faulty compressor (or part thereof). What I still need to understand is how this might have triggered an intermittent low oil warning? Any expert that can explain it to me would be greatly appreciated - I own an Alfa to learn more mechanics, and boy am I learning
