...Thousand miles.
Since I am now having to strip the engine down to do my clutch again, My thoughts are now on my Timing belt which is due in July (was last changed in 2009 at 60'000miles).
I have seen a lot of people here mentioning the need to rebuild the engine at 80'000 miles so I am thinking of doing some head work at the same time.
80'000 miles, It doesn't burn any oil at all and the only coolent it looses is what seeps out the edges of the radiator (new one going in shortly). It does however have a slightly weak/juddery idle which a spark plug change didn't help, although there are a few bits of damage on the inlet hose which could be contributing to that.
Should I replace the head gaskets and re-grind in the valves while I am doing the belt change? Would the head need to be skimmed while I am at it? I don't think I need to touch the liner seals or bottom end bearings as it is not using any oil and there is no contamination.
