Hello, I just purchased an '88 Graduate . Car ran great on inspection, on way home 2 days later and it stalled and wont re-start. I added fuel to the tank. Still no start. It sat for 2 days in drive way. I tried today, heard the fuel pump ,started and ran for about 30 seconds and stalled.Now all I hear when I turn key is the solenoid click and no fuel pump sound. I also cleaned several grounding points, it has new battery. The engine cranks/turns well but does not fire.Any suggestions ???
I'd first suggest you eliminate a no spark condition (engine cranking doesn't necessarily mean it is sparking, as you know)....ie. check you have spark: so one can concentrate on fuel and other things.
If there is a no-spark, then make sure the battery has adequate voltage 'whilst cranking' the starter.
L-jetronic requires 10.5V-10.8V min. whilst cranking, for the computor to wake up.
If you indeed have spark.....
then next check would be the fuel/drive relay (that is the big bosch relay) under the rear parcel shelf, and it's associated in-line 8A bullet fuse and holder (the holder causes lots of problems, many spider owners have got rid of the bullet fuse holder and replaced it with a modern spade fuse holder: http://www.alfabb.com/bb/forums/spi...in-fuel-pump-fuse-replacement.html#post822688)
You could bypass the relay (jump it) and see if the pumps run...herein described:
http://www.alfabb.com/bb/forums/1069165-post5.html
remember you have 2 fuel pumps one in the tank (puller), one under the car(main)....both need to work for it to drive well.
then next check would be the fuel/drive relay (that is the big bosch relay) under the rear parcel shelf, and it's associated in-line 8A bullet fuse and holder (the holder causes lots of problems, many spider owners have got rid of the bullet fuse holder and replaced it with a modern spade fuse holder: Main fuel pump fuse replacement? - Alfa Romeo Bulletin Board & Forums)
Alfa Romeo Bulletin Board & Forums - View Single Post - Testing fuel pump relay
Hello, thanks for your reply. I'll remove and replace that tomorrow. I'm hoping that is it, before I delve into the more complicated remedies, the car ran great then stopped. Ill charge the battery and clean the battery ground cable at the body , it is rusty/coroded.
The Bosch relay does click when turning the key on/off.
