I'm replacing water pump in '84 Spider. Radiator out, plenty off room, all 9 nuts removed, the pump slides forward on the studs, but bottom of pump bumps against back of crank pulley (correct term?). Cannot clear at least two studs on bottom of pump, so I can't rotate it. Crank pulley appears to be fastened by very large nut in front. Any tips?
