L
Does anyone know if the running gear form an '84 RWD GTV6 [ 2.5 ] will fit directly into a 75's shell?
Engine and gearbox certainly should.....not sure about the propshaft (length) but basically the cars are the same mechanically.
my gtv6 has a 75 3.0 engine in which is a plug in and play so vice vers is also the case The 75 does have a longer wheel base but the prop will fit the gtv engines flywheel
wont the 92 75 have a different fuel injection sysyem though
