Does any one know the different between alfetta and 75TS gear box mounting? Someone told me that they are different and 75TS, cannot use the mounting from an alfetta.
if I remember correctly, there is a plate on the bottom of the 75 mount that alters the height of the gearbox, makes it sit a bit lower I think. It can be removed if fitting a 75 mount to an Alfetta, but if going the other way, you will need the spacer plate off the old one. Mounts are £16 each from Highwood Alfa acording to their site, so not too expensive for new anyway.
HTH
I did actually try an alfetta mount on my 75. Result in very stiff gear shift, and couldn't slot it to 1st sometimes.
The one from highwood are for alfetta's not 75. Does anyone know where I could get a original 75 gearbox mount on the net?
I did think mine came from Highwood, a couple of years ago, so I may be wrong.
In that case EB spares are a sound bet.
HTH
