Hi, have a new (to me) 2.5 litre 75. can't get it to run properly. will only run with the fuel pump fuse removed. if the fuse is in it will crank but not fire. pump starts with cranking but stays on when key is turned off. remove fuse, engine runs ( badly) till it runs out of fuel pressure. have replaced telemetric relay, cheked all plugs in loom. before i go crazy, has anyone seen this symptom before, or, does someone have the group 00 manual? Cheers Greg
