Hi Alfa Owners!,
I have a very strange behaviour on my 2015 Giulietta 1.4T 170 BHP 940 model.
Since a while, the 3rd break light (the one on the spoiler) never turns off, even when I shut down the car. Instead, it dims a lot, but keep on. When I break, it turns to maximum and then dim when I release the pedal. Because it is led and dims I am not having any problem with the battery.
I was able to buy an used one and change it, and the behaviour is the same.
Any Ideas?.
Thanks!!!!
for starters i'd take the light out and check the connection for corrosion.
Thanks!, I tried 2 different lights (the original and a spare part I bought), and the same with both. Do you think that can be something with the cable?.
Check the wiring harness through the rubber gators from car to tailgate for broken insulation and shorting across circuits.
Here’s a wiring diagram for brake lights.
Also colour code table for wires.
if wiring checks out on tailgate I would have a check of the BCM output,you might have to split the green/black cable from plug F pin 48 to see what side the cable is getting slight power from.
Thanks Johnny!!!, this is pure gold!!!!. I will review today and write an update.
I would say you have an issue with the Driver Chip for the brake lights in the Body Computer.
Very happy to be wrong, fingers crossed.
  • Like
Reactions: DiegoSon
fit a resistor across the third brake light if you can't find a solution. 600 to 1000 ohm should be perfect, half watt. It will consume the current that's lighting the leds dimly, but won't affect normal operation.
Discussion Starter · #8 ·
Thanks for the advise, I will run all the diagnostic this afternoon and if I fail to find the source, this sound as a great solution!
