Hoping someone can help me with my question.
I have tried searching but the first 50 results didn’t come up with anything and the next few pages seemed irrelevant...
Now I have found a set of Teledials... On the to do list is converting to 330mm brakes and some have come up for sale recently. The seller thinks I will need front hub uprights they have - but I don’t think I need to.
Can anyone confirm what’s actually needed along with the callipers? They are coming with discs, pads (probably change them), braided lines and bolts. Is the mounting bracket a separate item or part of the calliper? Am I right in assuming the uprights aren’t needed?
954929
yes along as hes removed the caliper carrier bracket from original leg and the bolt spacing are the same .im not aware of a carrier difference between 305 and 330mm legs.. ask Pud237
954934
The 330 callipers are radially mounted on right-angle adaptor brackets (with the two big allen bolts) that then bolt to the standard GTA uprights. In the same place as the lug mounted 305 callipers.
As far as I can remember… :)
99% certain they will go straight on where the 305mm were. When Alfa carried out the 305 to 330 upgrade on my first GTA, was just the callipers / discs / pads and poss. lines.
Only need the hubs if you were fitting them to say a GTV / non 156 GTA etc...
If you have a GTA with the original 305mm brakes and you want to fit 330mm brakes, you just need the 330mm calipers, the radial-mount brackets, the big allen bolts, discs & pads. Hoses are the same, hubcarriers/uprights are the same.
If it was a Twinspark, 2.5 or diesel then you would need the hub carriers and you'd have to mess about with hub flanges, bearings, hoses, track rods etc also.
