30A Red Relay's 3.2 V6…...
2 red relays, situated in front of the battery on the 3.2 V6 engine. I know one is for the fuel pump what is the other one for?
A/C compressor I think. Black ones are for fans. It usually says on the lid that covers the relays but that only helps if they haven't been unclipped and put back on in different places.
Cheers Dan, I've lost the lid somewhere along the line. The reason I ask is after replacing the fuel pump relay I've had the 'motor control system failure' warning come on intermittently. Would the A/C compressor trigger that?
reading the error would help ;)
Then you NEED one! ;)
Can't live without it which you will be well aware of as soon as you start using one.
