Hi All,
Yes it's me again.
50 miles on brand new clutch mk2 and a high pitch squeeking noise has started from the clutch housing. It sounds exactly like the squeek you get on a squint pully on the Aux belt system but is from the wrong side of the engine.
The noise goes immediately when I press the clutch pedal and returns when I rev the engine up or leave it to idle for a while.
I am also noticing a slight shunt in the drivetrain when I engage first gear. When I dip the clutch pedal the engine note changes and is a lot deeper. It also judders very slightly in 1st and reverse with steering at lock (so only noticeable during parking manuevers I don't think Either of these symptoms where present on new clutch mk1.
Apart from that it is perfect, I am at a loss as to what could be wrong. All spring plate bolts were torqued correctly and with loctite and the clutch was aligned perfectly on installation.
Only thing out of the ordinary is the gearbox is slightly overfilled. Despite draining everything out of the gearbox and putting in exactly 2l in, it is about 1cm over the max mark on the dipstick.
Yes it's me again.
