Hello to everyone,
I've recently purchased a 159 3.2 JTS Q4 with a stretched timing chain (surprise surprise) and begun the whole process of importing a complete Cloyes timing chain set + original GM VVT's.
Gathering information on the two designers (first design 92 link roller chains or second design 114 link silent chains) applied, on one of the forums (not here) I received a suggestion to replace my old (and stretched) early design chains for a complete set of the new type silent chains along with VVT's (obviously also matching the new type of chains), as from what I learned (and that user highlighted) the second design silent chains are said to be more durable and long-lasting than the roller typ.
Having in mind that I would be replacing the complete set with sprockets, tensioners, guides as well as VVT's it seemed reasonable to me that such a swap should "work" without any problems (especially that from what I understand, apart from the chains, guides and sprockets there where no changes to the engine construction/setup/parts?) - so I went ahead and ordered the new type timing-kit.
I nearly collapsed on Friday, when my friend running the garage that's doing the replacement phoned me up to say they put the engine together and my 159 is running all wrong. At first he suggested it may be an issue with the new VVT's, as once they filled up with oil it's possible (from what he said this does occur) that they gone off the alignment marks and therefore the engine isn't running as it should.
They took it apart once more to check the marks (and the marks have in fact gone off by a few degrees), but after re-aligning the VVT marks and putting everything back together, today I received another call that it's still running like a tank and at this point he believes that swaping the first design timing kit for the second design isn't possible after all..
I'm pretty much devastated, as getting the parts organized, packed&prepared for alternative shipping and delivered to Europe plus then fitted to my car, apart from a good few bucks it also took over 8 weeks and it's possible that all this went for nothing (adding around 3 days of constant garage work around the car trying to find the problem on top of that). At this point I would like to ask has anyone ever performed such a "swap" before and is there any way to get this done correctly, or am I screwed big time?
I really hope that perhaps some sensor has changed along with introducing the second type of chains and very strongly hope it will be a matter of replacing a sensor or some other small part that may be causing a misreading of the timing chain position, not allowing the engine to run properly.
I know there's a number of highly qualified mechanics and engineers around here that have a great deal of knowledge - also on the JTS engines. I very much ask for any support possible, there might be something we didn't take into consideration or simply overlooked - but then again if it's definite that I screwed up by not verifying this idea with people more experienced and knowledgeable than me prior to ordering the parts and this swap simply can't be done, please pour a bucket of cold water on my head.
What will be left is finding a way of fixing this mess (and obviously paying the price for being an idiot that wanted something "better"). In any case, many thanks for making it through the read (as well as for any input whatsoever), I also hope this will be useful for others in for future.
My best,
e.
My best,
e.
