Ive read some where that the gtv rear exhaust manifold has a better flow when fitted to the gta 3.2
Now seeing as the gtv gt gta 3.2 have all the same engine does that mean my gtv has the same mainifold as the gta or does it have a gtv manifold
If it has the gta manifold would i be better off changing it and if so does anyone know the part number as there are two for the 3.0 gtv
Thanks in advance
Your 2005 gtv has the same manifolds with precats as a GTA.
The GTV manifolds that are talked about in swaps are the ph2 non cat ones.
You could replace yours for early ones as a power increase mod.:)
Thanks. How easy a swap is it and do you have the part number please
Would it be possible to send me a quote fior the job including the equal length down pipes. You can send me a pm Thanks
