Hi all,
Finally finished fitting my 2nd replacement clutch today after 4 weekends (not 4 full weekends I hasten to add). Pleased to report that yes, it does work. And yes, I did remember the heat sheild this time. I did pinch the Diff output seal O rings though and had to wait a week for replacements
All is not so rosey though. The engine started quite poorly, gave a quick blink of the MCSF light before settling into its normal idle. I wend for a test drive and if I gave it any more than 1/4 throttle the engine would die for a second, giving the motor control system failure error. Doing it stationary I would even get an immobilisor failure.
It's too late to do anything more now but would it be a safe bet that I have missed an earth somewhere? I got the gearbox and plenum earths done up, I don't think I could have missed any others.
I may had not properly tightened the nuts that secure the ECU to the plenum. Would this cause any issue?
and finally, can anyone show me the correct routing of the Power steering pipes that go over the gearbox? I cannot for the life of me get them to sit in the brackets on the subframe/inner wing. The one that goes to the resevior just wants to scratch the hell out of the inner wing and I cannot get it to comply!
