Not sure which threadlocker to buy for the vulnerable hub bolts.
Maybe the 271 as it has a slightly lower breakaway torque.
Loctite 271
Loctite 271 High strength, low viscosity Threadlocker, Breakaway torque 26Nm
Datenblätter Datasheets Manual Dispensing Manual Dispensing
Technical Data:
Maximum thread size: Up to M20
Strength: High
Breakaway torque M10 bolts: 26Nm
Fixture time steel: 10 min.
Fixture time brass: 5 min.
Fixture time stainless steel: 15 min.
Service temperature range: -55°C - +150°C
Pack sizes: 5ml, 24ml, 50ml
Loctite 270
Loctite 270 High Strength, general purpose threadlocker, Breakaway torque 33Nm
Suitable for all metal fasteners, including stainless steel, aluminium, plated surfaces and chrome-free coatings
Tolerates slight contaminations of industrial oils, e.g. engine oils, corrosion prevention oils, cutting fluids
Ideal for permanently locking studs on engine blocks and pump housings
To be used if regular removal for maintenance is not required
Technical Data
Strength: High
Breakaway torque M10 bolts: 33 Nm
Fixture time brass: 10 min.
Fixture time stainless steel: 150 min.
Service temperature range: -55°C - +180 °C
Pack sizes: 10ml, 50ml, 250ml
we are talking about the 4 bolts that hold the strut to the hub ?
i would use neither to be honest, just wire brush the crud of the bolts, copper slip and tighten to correct setting. job done
that way of you have to dismantle in the future you will find it will come apart as intended and the bolts wont be corroded
yes correct.
Ok I'll take your advice, no loctite then. I have already wire brushed them spotless and tightened them up but not up to 4kg-m yet. That is this weekends job to torque up all bolts and check.
4-4.7 kg-m seems a bit tight considering the small thread area but I guess AR know what they designed!:lol:
last thing I want to do is strip them again. They have already been repaired costing me 40 quid.
