1 - 13 of 13 Posts
Standard tyre size is 235/35/18 on the GTA....most, including me, went for 225/40/18 as a cheaper replacement.
Just wondered if anyone had tried 235/40/18?
235/35 -> 225/40 is a 2.5% increase in circumference, putting the speedo out by close to 2mph but giving less tyre width (less grip, but less tramlining?)
235/35 -> 235/40 is is 3.7% increase in circumference, and putting the speedo out by 2.7mph. More grip, more tramlining.
My reason is, I don't like the "strech" on 225s, both in terms of look and rim exposure, plus the extra grip from 235's could be quite useful.
Anyone tried it?
The 156GTA was always 225/40R18, the GT too.
Only the 147GTA had the totally unobtainable 235/35R18
Bump on this as I'm due!
I see Trailbraker (used to?) use 235/40/18's, but if anyone has tried it, info appriciated as I don't want an expensive mistake!
A
Yes, they will fit and look better than 225 imho. Hopefully you have some normal ET wheels and no spacers ;)
AO Car Of The Year Winner 2015
In the registration papers to my GTA I have 225/40 R18 and 235/35 R18 as aproved sizes. However as David says, you must be really lucky to get 235/35 as there is almost no choice and no stock.
I think 235/40 MAY need spacers but I am not sure. I bought the GTA with 235/35 R19 and they didnt scratch anything but needed 15mm spacers. However, I dont remeber what ET they were as they were not Alfa wheels....
...However as David says, you must be really lucky to get 235/35 as there is almost no choice and no stock.
I checked on mytyres.co.uk today and they have Dunlop in that size for £244 each...!!!
You can get the 35's, but they're stupidly expensive.
Don't see any reason why the 235/40's would cause serious issues in terms of clearance. I'm on coilovers on the Alfa (GT) multispoke wheels, but they're fairly recessed (I was considering spacers). Its not a massive increase in size.
I guess I'll just have to suck it and see ;)
I agree there is no point looking at 235/35R18, availability and price makes it a crazy option and by the way that Dunlop is a Runflat so you can't use that unless to fit pressure monitoring anyway.
235/40R18 may fit, but what size rims are you putting them on?
It's a no-brainer isn't it for the GT multispokes?
225/40/18, loads of choice, much cheaper and they definately fit with no rubbing etc.
I've got the GT Multispokes as Alexandrus mentions.
Prices aren't that much more - my reasoning is down to looks and alloy protection, as the 225's are stretched over the rim.
A
Plus, 235/40/18 is getting more and more common, most german manufacturers are switching from 225/40 to 235/40 so tyre manufacturers will follow ;)
1 - 13 of 13 Posts
