1 - 13 of 13 Posts
Was wondering what to expect from my car. I hear these cars are now built to last longer than previous alfas and the one I just bought looks to be in perfect working order still after 1 week (no hidden surprises from the dealer as of yet) I know the car is due a service but apart from the usual car probs what are the main things to keep an eye out for, or the main issues with the gt 1.9 jtd. My last car was an astra 2.2 coupe and I was propper peed off with all the electrical probs I payed out on abs pumps speedo problems car cutting out all time ........ And on and on. What have I bought into u all seem quite helpfull
treat it well it will serve you well .......service it regularly at an specialist alfa and it will run sweet for years to come
I'd advise you to check for smoke / lack of power which would mean a dead turbo hose.
Also, a hard clutch mean the clutch mechanism's dead, even though it can be hard to spot (still haven't figured it out on mine as I can't compare it to another)
Last but not least because expensive, check for play in the door handle, if it has some, lubricate the mechanism and be nice to it, otherwise, :cry:
Just look after it and make sure it has regular oil changes to keep the turbo nice and healthy. Also (as I am sure you know) the cambelt and water pump needs doing every 60k or 4 years. Dual mass flywheels will normally last 100k +
Overall they are great all rounders.
p.s fitting a silicone lower turbo hose is also a must - on ebay or just give me a call
Gutted take all my first post back Talk about bad timing. The miss us just called abs and I think she said vdc light just come on car HELP
Did the speedo stop working as well?
(or should I say, did she notice the speedo not working!)
Yeh she phoned me to say light was on. told her to turn car off and then back on and she called back to say all was ok again speedo fine brakes fine. Why is it when women are on there way to spend money the car always fooks up
I think the car was trying to save you from the cost of her shopping trip!
Check the main ABS fuse in the morning.
1 - 13 of 13 Posts
