Yes and no ?That post sounded bad- if you have Scottish ancestry you should understand.
Recent repairs:Used to always start first time, then took a while to fire up on first crank. It would stop cranking by itself even though the key was in the crank position (I thought this was weird). Now struggles to start first time, but cranks strongly until I release the key. Usually starts second go but sometimes not convincingly. Problem only occurs in the morning (20 Celsius), never any issues rest of the day.
Generally driving OK, no performance issues that I have detected, perhaps a the odd splutter
Battery tests ok with carbon pile load tester. Voltage drops from 12.6 to 12.3 over night. Having to keep on charger. Alternator is charging OK. Starting issues do not appear to relate to battery voltage
I know I have a main bearing seal leak and there might be oil in the bell housing… not sure if that can interfere with the crank sensor operation
No fault codes stored
Troubleshooting so far:Fuel rail pressure sensor replaced. Crank position sensor replaced after stalling/starting problems (last repair). New battery July 2020. Starter replaced Feb 2021. Alt replaced Sept 2017. Plugs not due to be replaced.
Cam belt due for replacement at the moment
ThanksI thought maybe the fuel pump relay might be dicky and swapped the fan and fuel pump relay - no change
Ecuscan tells me the actuators and relays work, fuel pressure is regulated at ~50 bar, lambda signals from each bank are the same, battery voltage 13.7v at idle. Don’t really know what else to check.
I carefully sprayed some gas around the engine bay looking for keaks, no change in RPMs
Spark plugs were dry sooty black but that was after idling for 10 mins, electrodes OK
Sprayed the MAF with some dedicated cleaner
Catching up on some residual questions………OK. Nothing badly wrong there but a couple of things are a little unusual but I must remember you are in summer heat so probably mid-high twenty odd degrees.
The air temp is fairly high but somewhat expected due to heat soak.
MAF is rather low. It is lower than I've seen a 1.6TS at idle.
LTFT are leaning the mixture a little.
Your car has covered a fair distance and I'm guessing the engine hasn't been apart. I'm guessing you have the JTS hum of restricted airflow by 5000rpm. Maybe earlier?
At this point I'd definitely like to know what compression pressures are- especially when engine is cold.
If you like, you could try to get a maximum MAF sensor reading but it may need an assistant and I don't think your engine would sound nice at 6500rpm with a wide open throttle. It will probably sound like it is in its death throes.
With all the information so far, I think a temporary loss of compression is what you are experiencing. It is not unusual for direct injection engines to experience this.
Not a definite though. Just an idea.
The last petrol car I worked on delivered a measured 2.5 times stoichiometric air/fuel ratio* during crank, which may be more than the HP pump can deliver since when running only about 1.1 times would ever be required. Apparently the engine is designed to start from lift pump pressure, which presumably is why it is comparatively high.not sure why the fuel pressure does not rise to 50 bar during cranking
Started second go but that was not very convincing as if the engine was flooded (3-4s).
You have fuel going in (wet pistons) so spark or compression. I can’t explain why it would only affect the first start attempt but maybe try a throttle body self-learning procedure in case it is starving the engine of air?only 375kg/hr looks rather restrictive when you should see 460kg/hr at 6400rpm for the JTS.
