Key status at MAR is correct.
Battery seems OK but I'm not so sure right now.
Load test on battery suggests it isn't so bad.
Residual current draw test suggests car is OK.
I'm not sure what starter motor the JTS has but after finding 2 listing, I expect the high compression engine should have the 1.4kW one and the 1.1kW one is for the TS.
That suggests the starter should draw 130amps and another few amps for other electrics. Say 150amps total.
You could measure engine cranking speed with MES. Ditto battery voltage. It may be best to graph them simultaneously. I'd expect 11+ volts and 300+ rpm.
I don't expect spark plugs to be bad at 50k km. New will still be better though. I'm guessing car has been in regular use recently and there have been no changes to your fuel buying habits.
I tried getting data but ran out of time due to a couple of issues. I still have a question about the battery though because 12.3 volts equates to around only 20% charged. That would mean a lot of power needs to be drawn overnight yet there is as yet no sign of a significant parasitic drain.
