2002 156 jts running rich
4869 5
Hi all
Introduced myself a while back when I bought this 2.0 JTS as a project.
Replaced all valves etc (timing belt snapped)
Replaced clutch and concentric cylinder.
Replaced old fuel and ran injector cleaner through car.
I have replaced all wheel bearings and disks. Reconditioned the callipers. New copper brake lines fitted also.
Replaced various pulleys and fitted new timing belt kit.
New plugs. New oil etc.
Failed MOT however on emmissions : ( .......oh and one faulty windscreenwiper lol
No other advisories on MOT.
The problem is it runs rich (2.1 was the reading I think. 6x what it should be) at high revs.
runs very lean as it should on idle.
Replaced both lambda sensors and now it runs rich at idle and at high revs.....what the :eek::eek:??
MAF cleaned. Cylinder head was clean....no buildup of carbon deposits etc. There is a bit of 'white' smoke coming from exhaust when revving above 4-5000 revs.
FiatECu software is not giving any errors other than high readings for lambdas. Contacted rather unhelpful Alfa dealer and they suggested the JTS is known to have issues with air leaks which can cause this problem....then cut me off???
Any help with this would be appreciated.
Could be a crack in the induction pipework causing a miss-read of airflow into the engine. Take the induction pipes off and inspect them for cracks/splits etc. If nothing is visible try a dunk test. Seal both ends of the pipes with latex gloves, dunk the pipe in water and see if theres any air bubbles.
If the pipework is fine check the airbox lid is secure.
Also worth noting that the JTS can suffer with fuel injector problems which will affect emissions if there's a faulty injector.
Appreciate the input Tommy.....
Will try that tonight......some parts on the car didn't age well while sitting on a driveway for 3 years lol
As for fuel injectors....its possible I suppose......what is weird is the problems with the mixture are worse than before replacing lambdas.....it had really old fuel (5 years :p) when I first got the car.After rebuild it did run but very lumpy) Drained it and quarter filled tank with high octane fuel from Shell or somewhere). Also put 1/5 of bottle of injector cleaner through it.
It does misfire slightly at idle which settles after it warms up......oh and after MOT on the way home when we tried to accelerate hard it cut into emergency mode or whatever with engine management light on. No errors stored when checked. Will look later today.
thanks
What are you using to read the fault codes? A generic code reader may not be ideal, although for engine faults it 'should' work. Your best option is to download muliecuscan (free from www.Multiecuscan.net)
And buy a cable/set of cables either from Rarebear (fellow forum member) or search eBay for 'Alfa Romeo diagnostic cable's and buy a set from Buy-Me-From-Dan.
Given that the car has been stood for so long it may want a proper Italian tune up and plenty of good fuel and injector cleaner running through it (many of us use a bottle of Reddex every 3 tanks, even if you only put £20 of fuel in it!).
Oh, as for cleaning the MAF, it doesn't always work and depending on what you use to clean it can make the problems worse. Stuff like carb cleaner or electrical contact cleaner will leave a residue on the sensor element, the only thing really suited to cleaning a MAF is IPA and you have to be really gentle with it.
ok....
replaced MAF and removed filter temporarily from airbox...very slight improvement but still too rich. Disconnect lambda's and it run as it should eventually going slightly rich as the engine revs to 3-4000
the lambdas I bought came in a jiffy bag.no box.....we're not convinced they aren't goosed....am testing again with the old lambdas....one at a time to compare readings on multiecuscan.
ecu 'might' b a problem also if not getting correct readings.....hmmmm
will post in a few days.....funeral to go to : (
Discussion Starter · #6 ·
Thought an update was required.
Problem solved after some extensive research on the Bosch website (which has some great product info)
Lambda sensors are very sensitive. And the JTS needs the correct ones....also 5 wire not so common......4.9 wide are NOT going to cut it.....must be 4.1.......
Do not do what we did initially and bought the correct Bosch sensor but with the wrong connector.....the resister on the connector is calibrated for the specific car so you can't cut off and swap connectors.
Replaced 1x faulty coil......MAF.......Air Filter.........1x pre cat lambda (Bosch LS7156)
Self tested emissions and its passed so back in for MOT Monday......wish me luck :)
....and No I have not soldered the wires to the pins of the connector as some people have suggested......I still might but a 'wiggle' test produced no errors while MultiECUscan was running.....great piece of OBDII software btw.
