My problem is-
After driving the car from cold for 3-5 mins the rad fans are kicking in.
Both fans work as they should, first just one fan then both.
They do not stay on long ,10-15 seconds then stop,then start then stop ect
I do have a faulty thermostat, temp never gets over 1/4 mark unless its left on idle for quite some time.
Ive owned the car for some time now and have never heard the fans kick in possibly due to the faulty thermostat.
My thinking is the temp sensor has given up or possibly the water pump is failing.
Just strange how my temp gauge never, (even when the fans kick in) , past the 1/4 mark.
Any thoughts or ideas would be most helpful
Chris
Discussion Starter #2
Little update :confused:
Disconected the rad fans left the car to idle for 5-6mins to see if i could get the temp needle to 90 deg and the car cut out and now will not start!!!! the temp never got anywhere near 90 deg and the rad pipes were still warmish not hot
Help
Update 2
after leaving the car for 15-20 mins it started again with the fans connected and blowing away, only to cut out after 30 seconds or so.
AAAARRRRRGGGGGGGGGHHHHHHHHHHHHH
Update 3
AA on their way
I Gave up!!!!! The car almost tries to start, couple of chugs but nothing more. Both fans are still kicking in soon as i turn the engine.
