1 - 15 of 15 Posts
these problems seem to be none stop, - and i havnt even driven the car yet!
firstly, the power steering bottle is leaking, any ideas?
secondly, the windscreen washer bottle seems it hasnt been used for a long time and is full of grime, anybody know how to clean it?
thanks again!
R
thanks again!
1. Where is it leaking from, bottle or the hose?
2. Can't personally vouch for this, but I have heard that a denture tablet (Sterident?) works wonders.
its leaking from the top of the bottle i think by the lid
ive just soaked the bottle in a bowl of hot water and soda crystals (me mom recommended this to me, lol) but it doesnt seem to of worked!
The washer bottle ???? ................. Washing powder, some hot water........ a handful of ball bearings (or marbles) ........... Put the cap on and give it a good shake.......
Cheers to All
Peter
Cheers to All
Peter
Ive used this to good effect in the past, i use gravel from my driveway though, means my Son doesnt get upset when his marbles go missing:lol:
Cheers to All
Peter
ill give this ago, although i need to pop down to alfa to get a washer bottle cap, thanks
There's a filter on the washer pump that clogs up. Disconect the wiring from it and pull the whole thing out the bottle. The end of it will prob be covered in gunge. Mine always seems to be so I'm constantly doing this so know it works!!
you mean you dont have your own marbles?
i did, but i lost mine :eek:
chris, ye ive cleaned the filter and pump, thats sweet, but it seems that because there hasnt been a cap on it for quite a while (a bit of kitchen tissue was used to block up the top) its gone all filthy inside the bottle and seems impossible to remove
however, i fear that if i dont clean it out, then it will eventually clog up the filter again...
HI .If all else fails.I still have a washer bottle , p/s res & various switch's from the gtv im breaking.
Cheers rod
I did the same job today!. In a word, Bleach!!! Remove the bottle from the car, remove the pump. Block the pump hole up (I used a bolt, screwed it into the rubber) Put in a big slug of bleach and fill with water. Give it a good shake and leave for a few hours. Rinse out, voila! clean bottle!
J
Bicarbonate of Soda....works a treat :thumbs:
Take the bottle off the car, coupe of teaspoons of Bicarb, block the hole with the pump, leave it for an hour and it is like new
1 - 15 of 15 Posts
