Changed my fuel filter today as just got the car a few weeks ago and the fuel filter was quite rusty and shabby wasn't sure if its been done in a while. I sourced a UFI filter from Alfashop so should all be ok. It went well , however after fitting I got a bit paranoid.......
1. the filter is a little loose in the mounting. There is a bit of movement up n down but the mount is done up as much as it can go.
2. Put all the pipes back etc. Primed filter then ran engine all good no leaks. The pipes if I push them can go downwards a bit then push back up like under pressure a bit. They seem ok.
Is there anything that sounds dubious above?.
