1 - 18 of 18 Posts
Hi All
I am looking to replace my 2.4 20V mjet turbo as I believe the vanes are sticking ?
I am going to to strip it out ad clean it at the weekend.
I am not hopeful :(
Therefore my question is mine is an 05 plate are the turbos all the same on the 20V mjets ?
and how much Am i LOOKING AT FOR FOR A RECON / EXCHANGE UNIT ?
thanks Andy
In my file of "companies I might need sometime" is Midland Turbo in Nottingham. Thus, someone muct have recommended these people on this forum.
Home | Midland Turbo
My understanding is that the 20v should all be the same.
Keith
itll clean up nicely dont worry
wouldnt think of spending dosh just yet.........except on new actuator pipe, u may as well do that too
Gary
I am getting it re conned by a specialist with new bearings etc and then checked etc
just got to get it off this weekend!
Keith
I've used these on some pretty unusual turbos. They always seem genuinely interested and go out of their way to help wherever possible....without really charging anything out of the ordinary.
In the top 10 of companies I've dealt with. :)
now I now why the boost was so low from my howling turbo !
the exhaust impeller has disintegrated and taken out he VNT mechanism OMG
New turbo required
How much !!
I've used midland turbos - happy with result. A year on and still going strong. They thought it was impact damage to my turbo, but got it fixed 560 inc vat.
New turbo required
How much !!
more to the point where have all the bits gone?? u never said it whistled thats sign of damaged turbine impeller !
Gary
Discussion Starter #15
update
New turbo installed all fixed ! however still doesn't feel as boosty as my previous trusty 10V :(
Might be worth plugging in the diagnostics and seeing what PSI you are getting on full boost? I would have thought it should feel a fair bit quicker than a 10V!
Keith
Discussion Starter #18
Hi there
its getting better i have done 125 miles now ! maybe the ECU is still learning !
more worryingly the previous owner had put 6.5 litres of gearbox oil in so swapped it with 2.4litres as GM forums suggest no more overheating clutch release bearing and sweet gearbox now
I am warming to her !
1 - 18 of 18 Posts
