I bought a 2007 159 2.2 JTS in November of 2021. 203,000km on the clock and not in the best cosmetic shape, but seemingly mechanically sound, and it's run well since the first test drive. The only persistent issues I've had are an unpleasant smell of fuel at the back right wheel, and that it often won't start on the first try of the day (just chugs out at the end of the startup sequence), but it always roars to life on the second try and then starts fine for the rest of the day. MultiECUscan told me the intake valve timing solenoid was dead when I bought it, so I replaced both the intake and exhaust; I got a bit of misfiring on the first couple of starts after doing that but it seems to have worked itself out since.
Two days ago I drove it about 50km round trip, from stop start traffic to 100km/h on the highway, and it went like a champ. Fast forward to today, when five minutes from home the Check Engine Light started flashing and I had to put my foot right to the floor to make it up a hill I can usually cruise up effortlessly in fourth gear. I turned around immediately. Downhill and level driving were fine, but it gave me trouble going up every hill on the way back, misfiring terribly, jerking, flashing the light, making me feel like I was going to have to push it home. I slapped MultiECUscan on it as soon as I got home and the diagnosis is:
P0300 - Ignition Failures (generic)
P0303 - Cylinder 3 ignition failures
P1670 - Fuel Pressure
P0301 - Cylinder 1 ignition failures
P0304 - Cylinder 4 ignition failures
There's also a lot of fuel leaking down the right side of the tank, just ahead of the back right wheel. I wrestled the back seat out and found a crack in the plastic top of the pump assembly housing, so obviously I'll take care of this ASAP. I'm going to try to patch it with some JB MarineWeld in situ first (high pressure, fuel-resistant, works on plastic, worth a shot) but I suppose I'll get a new pump unit if that doesn't work.
Does anyone have any experience with the P1670 code, though, or misfires going uphill? I've searched the forum and seen the high-pressure fuel pump and fuel injectors mentioned, which has my stomach in knots, but nobody's symptoms seem to match mine exactly. Any advice would be appreciated.
