CAn someone tell me are these data correct for a cf3 2.0 TS
2.0TS stock cam specs:
Intake 3-51. With variator, 22-26.
Exhaust 47-4.
So it's 234deg intake / 231deg exhaust
Overlap: 7deg/26deg
aor are these the right ones:
inlet 0/55, 25/30 235
exhaust 50/8 238
or some other data. I found so many on the internet I dont know which are the right one
how many types did they use? cf2, cf3...? i have data that 1.6 cams are wilder then 2.0, with more overlap. the data is really confusing since there are so many versions for 2.0.
alan, for which 2.0ts are these data from?
ps: sretno sa 156 :)
I only have these data for the 1.6 cams
1.6TS stock cam specs:
Intake 8-46. With variator, 22-26.
Exhaust 26-4.
So it's 234deg intake / 210deg exhaust
Overlap: 12deg/26deg
And you can see that the overlap is bigger then on the 2.0TS, which should make them wilder. But when you say you gained something I will trust you. :thumbs:
You are right. Because the variator moves 25°, that means that my 1.6 data are totally incorrect but they are impossible to find. I find it funny that the variator switches off on late rpm and reduces overlap, when you need more overlap on higher rpm.
