1 - 15 of 15 Posts
A
Where is the best place to get a cheap exhaust from ?
I have a hole in the middle box, and the rear box is trying to let go of the tail pipe.
It's the origional system, hence no joints, so I need a full system from the CAT back.
Don't mind whether it is stainless or standard, just so long as it is cheap.
Thanks very much. :)
W
Discussion Starter #2
What do you call "cheap". Most tyre and exhaust places will be able to get you a Bosal type mild steel one for about £175-200 fitted.
You could also go for a Powerflex Stainless zorst for £300...the choice is yours.
Welcome to the forum btw ;)
wrinx
W
btw.....your can buy just the rear section, aftermarket systems are split.
wrinx
M
I got a cat back one piece section from National Tyres for 126 quid.
I think GGB ( think they are now called www.shop4parts.co.uk ) do them cheap. A V6 owner got a cat back for 80 notes recently.
A
Thanks for the replies. That is excellent info. :) Cheapest quote I had was £300 for a cheap one.
The National Tyres ones looks very interesting. That was a fitted price then ?
W
That is robbery :tut: ....I was quotes that when the car was two years old, prices have come down dramatically since then.
wrinx
A
Well I haven't had much luck today. :(
Rang national tyres and was quoted for a cat back system,
16v £275
8v 180+175= £355 :eek: :rant:
Rang protyre £215 (bosal)
Will ring a few other places.
Longlife near Bristol (Failand, just off M5) did me a stainless cat back system for my 145 for £320, it would have been £300 if I'd gone for a standard tailpipe. So, if you're looking at spending the best part of £275 for a mild steel system, I'd recommend spending the extra £25 for stainless :)
M
A member here had a Longlife zorst and it fell apart less than a year later. The warranty didn't cover their crappy welding etc etc so he couldn't get it fixed unless he paid.
Hope yours is better.
Andy have you tried the link I put in my first post ???
Really :eek: :eek: :eek: I went to Longlife because I had heard nothing but good things, whereas the powerflow experience seemed to be a bit variable. I guess I'd better check my warranty :(
1 - 15 of 15 Posts
