If I disturb the wires going into the relays in front of the battery tray I get problems! Either engine won't fire (injector warning light) or 1 fan stays on, or both fans stay on. I'm guessing that it can't then, be individual relays?
Has anyone else had this problem (and fixed it).
Where is the earth for this harness?
Small relay in a brown base in the injection system
Small relay in red base is the fuel pump
Small relay in black base is the low speed fan
Question though, you say "both fans stay on", a TS should only have a single fan (which can run at low speed or high speed).
Sorry meant low/high speed. I'm convinced it's not relays - seems to be harness
Corrosion? They aren't in the best place to avoid moisture. Worse if you don't have an undertray
